Network Management
Cisco Aironet2802
We are using Airwave for reporting on our wi-fi network but we are moving from the Aironet 2702 as a standard to the Aironet 2802.
Is there a timeline when the 2802s will be compatable with Airwave?
John
Re: Cisco Aironet2802
Currently we do have support for Cisco 2800 series devices in Airwave, I would recommend to raise feature request and follow up with your Aruba sales team for feature status.
Pavan
If my post address your query, give kudos:)
Pavan
If my post address your queries, give kudos and accept as solution!
Exceuse for type error, we do not have 2800 series support in Airwave
Pavan
Re: Cisco Aironet2802 support status
Any updates from Aruba regarding support features for Cisco 3650 controllers with AP2802?
Attached latest support device guide. Currenlty we does not have support, please file feature request and follow with your accounts team.
Pavan
Pavan
I see support was added for Cisco 3800 series APs as of 8.2.5.1, but 2800s are not in the list. Are the 2800s supported yet?
Moderator
2802E and 2802I are supported in LWAPP mode.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
