Network Management
Contributor I
Clarity - Authentication through captive portal and external authentication server
Hi erveryone,
I would like to know if the "Authentication" stats in the Clarity tab on Airwave take into consideration the authentications performed through a captive portal forwarding the authentication to an external authentication server.
Thank you!
François
Moderator
Re: Clarity - Authentication through captive portal and external authentication server
since this is very similar to the other thread (link), i'll mirror the same comment:
I've fwded to the team to see if there is any path for this.  I don't believe there's a path - in which case this might be fuel for a Request for Feature Enhancement through the ideas portal.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
