Network Management
Clarity Captive Portal Filter
We have multiple networks that use different methods of authentication, including a guest network with Captive Portal.
Is there anyway to get Clarity to ignore Captive Portal authentication failures? As it stands, we are quite liking the look of this feature, but it is essentially un-usable as an "at a glance" feature due to the number of errant failures due to the general public attempting to login without an account.
Contributor I
Re: Clarity Captive Portal Filter
That's a very good question. I would like to know as well.
Moderator
I've fwded to the team to see if there is any path for this.  I don't believe there's a path - in which case this might be fuel for a Request for Feature Enhancement through the ideas portal.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
