Network Management
Clarity data missing in Airwave
My Airwave is only showing DNS data in Clarity, the rest is NA...
We are running Airwave version 8.2.2 and ArubaOS on a 7210 Controller.
I've been doublechecking mgmt-servers on the Controller and it shows the correct IP of the Airwave server with mgmt profile set to "default-amp".
Inside "default-amp" everything except UCC Monitoring and Airgroup Info is enabled.
In Airwave the "Enable Clarity Data Collection" is set to Yes.
The firewall between Airwave and the Controller has the following ports opened: udp-8211, https, syslog and snmp-trap.
What am I missing here?
