Network Management
Configuration Stuck on Verifying
This thread has been viewed 19 times
  • 1.  Configuration Stuck on Verifying
    Posted May 04, 2018 12:01 PM
    Within the last two days, one of my clusters is saying that the configuration is Verifying. I have not changed anything to cause this. I have rebooted the AP's and the VC and its still stuck. i do not have any pending changes that wouldve caused this. Any ideas?
    edit.... heres another screenshot.
  • 2.  RE: Configuration Stuck on Verifying
    Posted May 04, 2018 12:41 PM
    Generally: check device audit logs.  If nothing in the audit logs, try the error log to see if maybe there's an empty value causing a crash.
    What version of AirWave, IAP model, and IAP firmware do you have running?  Are IAPs managed template based of by Instant GUI Config?  If IGC, check IGC logs as well.
  • 3.  RE: Configuration Stuck on Verifying
    Posted May 04, 2018 12:52 PM
    AirWave Management Platform 8.2.5
    ArubaOS (MODEL: 205), Version 6.4.4.8-4.2.4.9
    and yes they are configured using the instant config.
  • 4.  RE: Configuration Stuck on Verifying
    Posted May 07, 2018 09:26 AM
    not sure why the last message was deleted, but this is whats in the igc.log file. it just keeps repeating this.
    2018-05-07 07:49:59,975 INFO  Core[1]      com.airwave.config.services.MessageService Received message with type: bootstrap
    2018-05-07 07:49:59,975 INFO  Group        com.airwave.config.services.GroupService Group Access Points instant_gui_config status is 0, discarded
    2018-05-07 08:04:59,975 INFO  Message      com.airwave.config.services.MessageService sending:
    {"command":"bootstrap"}
    2018-05-07 08:05:00,231 INFO  Core[1]      com.airwave.config.services.MessageService Received message with type: bootstrap
    2018-05-07 08:05:00,231 INFO  Group        com.airwave.config.services.GroupService Group Access Points instant_gui_config status is 0, discarded
    2018-05-07 08:20:00,231 INFO  Message      com.airwave.config.services.MessageService sending:
    2018-05-07 08:20:00,511 INFO  Core[1]      com.airwave.config.services.MessageService Received message with type: bootstrap
    2018-05-07 08:20:00,511 INFO  Group        com.airwave.config.services.GroupService Group Access Points instant_gui_config status is 0, discarded
    2018-05-07 08:35:00,511 INFO  Message      com.airwave.config.services.MessageService sending:
    2018-05-07 08:35:00,762 INFO  Core[1]      com.airwave.config.services.MessageService Received message with type: bootstrap
    2018-05-07 08:35:00,763 INFO  Group        com.airwave.config.services.GroupService Group Access Points instant_gui_config status is 0, discarded
    2018-05-07 08:50:00,763 INFO  Message      com.airwave.config.services.MessageService sending:
    2018-05-07 08:50:01,034 INFO  Core[1]      com.airwave.config.services.MessageService Received message with type: bootstrap
    2018-05-07 08:50:01,034 INFO  Group        com.airwave.config.services.GroupService Group Access Points instant_gui_config status is 0, discarded
    2018-05-07 09:05:01,034 INFO  Message      com.airwave.config.services.MessageService sending:
    2018-05-07 09:05:01,502 INFO  Core[1]      com.airwave.config.services.MessageService Received message with type: bootstrap
    2018-05-07 09:05:01,502 INFO  Group        com.airwave.config.services.GroupService Group Access Points instant_gui_config status is 0, discarded
  • 5.  RE: Configuration Stuck on Verifying
    Posted May 07, 2018 11:29 AM
    update
    had to make a change to another one of my vc's at a different location. it to is now stuck in verifying. so i looked at the /var/log/config_pusher file and its not pushing the configs. how can i force the push from AirWave?
  • 6.  RE: Configuration Stuck on Verifying
    Posted May 08, 2018 04:37 AM
    1. Go to VC monitor page to check if this VC has in-process/failed firmware or DRT(8.2.6.1) upgrade job? if yes, please make sure remove the job and try again.
    2. Check VC > Alerts & Events > Recent AMP Device Events will provide some useful infomation.
    3. Check AMP Setup > Permanace > Maximun number of config process and maximun number of audit process, if value is too low, please set them both to 20.
    if issue still, please help to upload:
    VC monitor page screen shot
    VC > Alert & Events > Recent AMP Device Events
    igc.log file
  • 7.  RE: Configuration Stuck on Verifying
    Posted May 08, 2018 08:22 AM
    i rebooted the AMP and that fixed the issue. also worked with support last night and they stated that for 200 access points and 500+ connections, that 8 GB of RAM was to low. the swap RAM was at 4GB. so we increased the VM's RAM to 20GB.
    This is what was going on at first, as you can see the usage was strange
    now that we have changed the RAM heres what it looks like now.
  • 8.  RE: Configuration Stuck on Verifying
    Posted May 04, 2018 01:02 PM
    rgin heres what i see in igc log
    2018-05-01 14:04:20,257 INFO Group com.airwave.config.services.GroupService Group Access Points instant_gui_config status is 0, discarded
    2018-05-01 14:19:20,257 INFO Message com.airwave.config.services.MessageService sending:
    2018-05-01 14:19:20,727 INFO Core[1] com.airwave.config.services.MessageService Received message with type: bootstrap
    2018-05-01 14:19:20,727 INFO Group com.airwave.config.services.GroupService Group Access Points instant_gui_config status is 0, discarded
    2018-05-01 14:19:39,691 INFO Core[1] com.airwave.config.services.MessageService Received message with type: update
    2018-05-01 14:19:39,692 INFO Group com.airwave.config.services.GroupService change type[update] for table[ap]
    2018-05-01 14:20:38,159 INFO Core[1] com.airwave.config.services.MessageService Received message with type: update
    2018-05-01 14:20:38,162 INFO Group com.airwave.config.services.GroupService change type[update] for table[ap]
    2018-05-01 14:21:39,780 INFO Core[1] com.airwave.config.services.MessageService Received message with type: config
    2018-05-01 14:21:40,307 INFO Message com.airwave.config.services.MessageService sending:
    {"command":"audit_result_update","ap_id":211,"audit_status":"Good"}
    2018-05-01 14:36:40,311 INFO Message com.airwave.config.services.MessageService sending:
    2018-05-01 14:36:40,758 INFO Core[1] com.airwave.config.services.MessageService Received message with type: bootstrap
    2018-05-01 14:36:40,758 INFO Group com.airwave.config.services.GroupService Group Access Points instant_gui_config status is 0, discarded
    2018-05-01 14:51:40,759 INFO Message com.airwave.config.services.MessageService sending:
    2018-05-01 14:51:41,217 INFO Core[1] com.airwave.config.services.MessageService Received message with type: bootstrap
    2018-05-01 14:51:41,217 INFO Group com.airwave.config.services.GroupService Group Access Points instant_gui_config status is 0, discarded
    2018-05-01 15:06:41,218 INFO Message com.airwave.config.services.MessageService sending:
    2018-05-01 15:06:41,666 INFO Core[1] com.airwave.config.services.MessageService Received message with type: bootstrap
    2018-05-01 15:06:41,666 INFO Group com.airwave.config.services.GroupService Group Access Points instant_gui_config status is 0, discarded
    2018-05-01 15:21:41,667 INFO Message com.airwave.config.services.MessageService sending:
    2018-05-01 15:21:42,327 INFO Core[1] com.airwave.config.services.MessageService Received message with type: bootstrap
