Network Management
Frequent Contributor II
Configure IAP and Mobility Controller from AirWave
I have a simple question: is it possibile to confiugure parameters of IAP and Mobility Controller directly from the AirWave page?
Massimo
Massimo Gallina
Telecommunications engineer - ACMP2013
Aruba
Re: Configure IAP and Mobility Controller from AirWave
Hi Massimo.
Sure, both of those platforms can be configured from Airwave.    We are working on making the IAP configuration easier to use at the present time.
JF
Thanks for the reply JF!
Massimo Gallina
