Network Management
MVP
Configuring new 7210 - getting Unknown Engine ID for various monitors
Greeting All,
I've missed something obvious I'm sure, but can't see it.
I've set up a new 7210 (replacing a 3600) in one of our warehouses, and moved a couple of APs to it. All seems to be well, but Airwave is unhappy about my SNMPv3 settings.
I have the same configuration (excepting hostname and IP addresses) as any of several other 7210's, yet Airwave continues to report "Unknown Engine ID" for most SNMP monitors.
Which obvious, but currently hidden setting did I miss?
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
Re: Configuring new 7210 - getting Unknown Engine ID for various monitors
Hi Matthew,
Any change in the controllers clock? Found the below document in community,
https://community.arubanetworks.com/t5/Controller-Based-WLANs/SNMPv3-errors-after-upgrading-to-AOS-5-0/ta-p/174934
Vishnu
Vishnu
If my post helped you, don't forget to give kudos ;)
MVP
I thought I replied, but I don't see it here.
The clock was wrong - right three-letter-zone, wrong offset, but fixing that didn't fix the issue.
While working with TAC I dug through my case history and found that I had the same problem in March 2015. TAC "solved" that by restarting the poller and a few other services.
I "fixed" my problem by restarting AMP (which included all services and pollers, so slight overkill, but fast) and now I have new APs to import.
--Matthew
