Network Management
Connection Between Controller 620 and AP 105 Aruba
Hello good afternoon to the whole community, I have a small problem with my laboratory and I'm doing an installation in my network of a 620 controller and an AP 105, the controller configuration is checked and it is good to connect the AP it takes it as an air monitor and will not let me out of that state. I tried restarting the AP but in turn it keeps giving me the same error. Someone here will have an idea why I have this problem?
Re: Connection Between Controller 620 and AP 105 Aruba
What version of ArubaOS?
What is your regulatory domain?
Type "show ap database long" on the commandline of the controller to see if your AP has any flags.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
in the indicator this 2E that according to the history it seemed to be the unregulated regulatory domain
