Network Management
Contributor II
Controller Detected down on AirWave
Hi All,
i have some problem with AirWave.
Why my controller detected down on AirWave ? i already re-attached the controller to AirWave, but failed. This problem still persist.
what should i do ???
kindly need your advice
Re: Controller Detected down on AirWave
How long has this been happening?
Is there a firewall between Airwave and the controller?
What is the down message it is showing  in APs/Devices>Monitor page of controller in Airwave? If it failing with snmp time out / device unreachable/ICMP error then you have to check below things
  • Make sure you have proivded same community string in APs/Devices>manage page of the controller, which you have configured in controller.
  • Try ping the controller from Airwave command line to check whether it is reachable or not? If it is not reachable then check snmp port is allowed in firewall.
  • If it reachable and community string is correct then try increase the snmp timeout/retries value in Devices Setup > Communication page.
Pavan
If my post address your queries, give kudos and accept as solution!
