Network Management
Controller Issue
  • 1.  Controller Issue
    Posted Mar 04, 2016 09:52 AM
    Hi Guys
    I totally schrewed things up. In the Rap Wizard i activated firewall on all ports, so now I cant reach the web interface at all. I would like to remove that firewall from all ports so that I will be able to use the Web GUI again. What I tried to do was to have a RAP and have that RAP to provide DHCP and be able to reach datcenter servers. Could anyone help me with what commands I need to run to get back the web GUI again
    Hans Orbert
  • 2.  RE: Controller Issue
    Posted Mar 04, 2016 10:01 AM
    You need to find a way to VPN in and fix your issue.  If you cannot get to the controller using a RAP, you need to find another way to do so...
  • 3.  RE: Controller Issue
    Posted Mar 04, 2016 10:03 AM
    Do you have SSH access?
    Borja
  • 4.  RE: Controller Issue
    Posted Mar 04, 2016 10:28 AM
    Hi
    Sorry, The only Way i van access is via cli
    Skickas med OWA för iPhone
  • 5.  RE: Controller Issue
    Posted Mar 04, 2016 11:19 AM
    You can either modify the ACL applied to your interface or remove it from the interface.
    show interface gig X/X access-group
    Check which policies you have applied to your interface and removed them
    conf t
    interface gig X/X
    no ip access-group AccesGroup
    If you need more specific commands or more help, could you provide output from your CLI?
    Regards
    Borja
  • 6.  RE: Controller Issue
    Posted Mar 04, 2016 01:22 PM
    I will try to remove first thing monday morning. I will post my result. Thnx for your input.
    Orpan
  • 7.  RE: Controller Issue
    Posted Mar 07, 2016 09:00 AM
    Thnx Borja
    I managed to free up mgmt interface.
    Regards
    Orpan
