Network Management
Creating an Alert for failed WPA2
Hi Airheads,
I tried to create a trigger that will alert the GUI icon , when
wlsxMgmtUserAuthenticationFailed is being sent from an SNMP trap.
(Because not all auth failuers are due 802.1x)
Attached screenshot:
Please advise how to accomplish this need.
Thanks.
Asa
Re: Creating an Alert for failed WPA2
Use wlsxNUserAuthenticationFailed trap event in trigger condition,This trap indicates that a user authentication has failed.
Pavan
Pavan
If my post address your queries, give kudos and accept as solution!
Thanks - but did u looked on the screenshots..that what i did - without results , even due , i checked the AW snmp trap logs , and i can see events like this.
Please advise
Me
Trap which I shared is different, try below condition along with trap which you are using
Pavan
Pavan
