I see a bunch of Rogue APs - most of them are probably nothing to worry about - e.g. just a neighboring companies wireless. However sometimes I see that people are setting up their own wireless units. I need to stop this for security reasons as well as channel interference. Is there anything I can do in airwave to block, flood or disable their device? Should I do anything in airwave to improve performance when dealing with neighbor's wifi?
Thanks - I appreciate the response. So you need to buy an additional software module? I can't find rfprotect in airwave or is it on the APs direct?
Thanks!
