Network Management
Delete-AP-Button not working in AirWave
Hello Guys,
recently we encountered a probblem with the current Version of AirWave.
We tried to delete some old APs from the "offline" list, Airwave says it will delet it in the background, but the APs still show up even after a day. The same problem occures with APs in the "new" list, which are no longer associated with the controller.
Has enyone the same problems or a solution to our problem?
AirWave Version: 8.2.0.1
Greetings,
Hendrik Lüth
Karlsruher Institut of Technologie (KIT)
Steinbuch Centre for Computing (SCC)
Moderator
Re: Delete-AP-Button not working in AirWave
We've seen this before in testing back in 8.0, depends on how busy the database is in the background.  Please open a support case so that someone can take a look.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
