Network Management
RMC
Occasional Contributor I
Detect Malformed Frame-Large Duration from MAC 02:00:00:00:00:00
Hi All
Again whilst investigating Airwave alerts I saw a huge number of Detect Malformed Frame-Large Duration from 02:00:00:00:00:00, about 10 000 a day, what are these and can they be ignored?
I've read the follwoing regarding changes in Android 6, though don't quite see how that correlates.
  • To provide users with greater data protection, starting in this release, Android removes programmatic access to the device’s local hardware identifier for apps using the Wi-Fi and Bluetooth APIs. The WifiInfo.getMacAddress() and the BluetoothAdapter.getAddress() methods now return a constant value of 02:00:00:00:00:00.
Any light would be greatly appreciated.
Mark
Re: Detect Malformed Frame-Large Duration from MAC 02:00:00:00:00:00
Feel free to uncheck "detect-malformed-large-duration" in the IDS dos profile.  There could be a problem with the combination of detection and that android device.
RMC
Thanks Colin.  I'll go ahead and ignore it.
RMC
Hi Colin
I should have added that Airwave also reports Malformed Frame Large Duration attacks from MAC addresses other than 02:00:00:00:00:00 however these are considerably less in count.  Is it still safe to turn off?
Many thanks
Mark
What version of ArubaOS
RMC
It's AOS 6.4.4.8, AMP is 8.2.0.2
We have the same problem in our environment, with a packet capture I can see that a device(s) using this MAC address is requesting 29000 ms of airtime, which is an eternity. Anyway to correct this?
