Social authentication will allow you to present several login options to your clients, i.e. FB, LinkedIn, or guest accounts created in Aruba Central.
If you select FB WiFi only, the user will be redirected to the FaceBook page, rather then your own Aruba Central Captive portal.
thanks,
