- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Different usage readings in controller GUI and airwave.
03-03-2016 02:54 AM
Hi
When I look at the usage in the controller gui dashboard, it reads 500M, but in airwave for the same controller it reads 202Mbps.
Why is there a difference between theese 2 readings ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: Different usage readings in controller GUI and airwave.
03-03-2016 04:08 AM
Victor Fabian
Lead Mobility Architect @WEI
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
03-03-2016 04:29 AM
Heres some screenshots.
The difference is not as big at the moment, but still 100M difference.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
03-03-2016 07:17 AM
Victor Fabian
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
03-03-2016 07:24 AM
I am not sure that I understand your question here.
I have 7210 controllers with APs attached, and are using airwave only as a monitoring platform.
In airwave I have the controllers attached, and can therefor monitor both APs and controllers.
Does that answer your question correct? :-)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
03-03-2016 07:37 AM
The other thing is that the information presented in the controller usage is over the last 15 minutes (default) and in Airwave by default is over the last 2 hours .
You can change the airwave time range for the usage but not in the controller dashboard
Sent from Outlook for iPhone
Victor Fabian
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
03-03-2016 07:45 AM
No, I'm not monitoring any wired data, or anything else but the controllers.
And yes, there is a diffrence in the time span, but I find it strange that the traffic in the controller GUI is always higher than what is showing in the Airwave. And sometimes nearly by factor 2.
Anyway, thank you for your answer.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
03-03-2016 01:55 PM
What version of AirWave and what version of AOS firmware? Is data polling from AirWave via SNMP or AMON? If SNMP, then the difference is probably due to latency from time of request/collection to time AirWave processes. If on AMON, then this would be a defect and should be looked into with a support case. Would expect the numbers to be very close (not realtime close, but within polling parameters).
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
03-03-2016 10:49 PM
I am running airwave 8.0.11 and AOS 6.4.3.5.
Datapolling is preferred to be AMON, but how can I see if that is actually the protocol beeing used?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
03-04-2016 07:16 AM
While the AMP may have the setting for AMON, you also need to verify it from the controller end.
From controller CLI:
# show running-config | include mgmt
(looking for a command that looks like:
mgmt-server type amp primary-server 10.10.10.10 profile default-amp
where primary-server = AirWave IP
and profile = whatever you decided to use for the AMON profile - in this case it's default-amp)
# show mgmt-server profile default-amp
Mgmt Config profile "default-amp" (Predefined (changed))
Parameter Value
Stats Enabled
Tag Enabled
Sessions Enabled
Monitored Info Enabled
Misc Enabled
Location Enabled
UCC Monitoring Disabled
AirGroup Info Disabled
Inline DHCP stats Enabled
Inline AP stats Enabled
Inline Auth stats Enabled
Inline DNS stats Enabled
A simplified breakdown of what these data points are:
1) general data collection = stats, monitored info, misc
2) VisualRF = location, tags (if you use wifi tags, example: ekahau)
3) UCC = UCC monitoring (Lync calls)
4) AppRF = sessions
5) AMP 8.2 upcoming feature: Clarity = the 4 'inline' stats
note that speed/goodput values for rf performance page are also transmitted via AMON
Rob Gin
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
