Network Management
Contributor I
Different value and unit reported for transmit power
I've been monitoring channel transmit power from Airwave. But then I decided to make a report out of it. Opun producing the report from Airwave report, I stumble into a problem to determine which value is correct between the dashboard and report and why does the transmit power reported from Airwave does not have any unit..?
Mohamad Syafiqul Haziq,
System Engineer, Mesiniaga Berhad.
Re: Different value and unit reported for transmit power
The transmit power on the report is in dBm.
Similar post.
Cheers
James
Cheers
James
-------------------@whereisjrw-------------------
------------------------blog-------------------------
