Network Management
paw
Contributor I
Disable Flash in Airwave
Hey,
we upgraded from Airwave 7 to 8 and the new HTML5 VisualRF looks geat. But if I go to APs and Devices, choose an AP, Goto monitor and I click on the area for locating the AP, Airwave opens the Flash Version of VisualRF.
I tried some things like disabling HTML5 and enableing it afterwards, other browser, deleted all APs form the floor plan an added them new to the HTML5 plan .... but still the same.
Is this a problem, or normal??!
Greets
Re: Disable Flash in Airwave
We're running 8.0.9.1 and seeing this issue as well. I've been meaning to open up a ticket as I imagine it should be linking to the HTML5 version of the map.
Have you tried turning off support for HTML 5 in VisualRF?
VisualRF -> SetUp -> Enable HTML5-based UI:  (yes/no)
You'll need to select another menu (..such us AMP Setup) so that VisualRF can reload.
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
paw
Contributor I
Yes, I did this. I have an open support case. Thanks so far.
This would be a small change in code mapping the right URL for the Floor Plan in AP. Instead of https://airwave/site?... it should map to https://airwave/vrf?... in the URL when you click on Locaton in AP Monitor page.
This has been fixed in 8.0.10 version.
