Network Management
Does Aruba clarity work with 3600 controllers and RAPs (configured to bridge local)?
Just wondering if this can work before spending time trying to make it work.
3600 controllers are in DMZ - Airwave isn't.
Airwave can see controllers - no issues there - should add this is monitor only mode.
Enabled amon and clarity but no data.
Was wondering if this had anything to do with the fact that it's mainly RAPs in bridge local mode being used.
