Network Management
ECCN and HTS codes for AP-205-F1 , the DS-7000 and DS_7200 series
I am trying to find out the ECCN and HTS codes for AP-205-F1 and the DS7000 and DS7200 series mobility controllers
I believe for the AP it is HTS 8517.62.0050 ECCN 5A002.A.1.  Is it the same for the controllers as well?  Thank you for any help.
Moderator
Re: ECCN and HTS codes for AP-205-F1 , the DS-7000 and DS_7200 series
Picking a few at random...
7010-USF1 Mobility Controller, FIPS/TAA, Restricted Regulatory Domain - US 8517620050 5A002 (A.1) ENC Restricted G157671 12/5/2014 US
7240-USF1 Mobility Controller, FIPS/TAA, Restricted Regulatory Domain - US 8517620050 5A002 (A.1) ENC Restricted G157671 12/5/2014 US
AP-205-F1 Access Point, FIPS/TAA 8517620050 5A992 NLR Mass Market Self-Classified   US
Jon Green, ACMX, CISSP
Security Guy
Thank you.  Would you know for 7010-RWF1, 7030-RFW1, 7030-JPF1, 7205-JPF1, 7205-RWF1, 7210-JPF1, 7220-JPF1, 7220-F1, 7240-JPF1, and CP-VA-500?
I tried looking all over the site, but couldn't find the information.
Moderator
The controllers are all the same, so it's the same as what I already posted.
CP-VA-500 is software.. as far as I understand it, export control doesn't apply to that.  There's no software SKUs listed in my spreadsheet anyway.
Security Guy
Correct, Bev confirmed there's no ECCN for software (Clearpass, AirWave, etc).
Jerrod Howard
You stated there was no ECCN or HTS assigned to SW but how is this designated if the SW comes predeployed on an appliances (server) directly from Aruba?
Mark
APs and controller hardware have an associated ECCN/HTS code
Any hardware appliances (servers for Clearpass or AirWave) would use the ECCN/HTS of the server vendor (which we can get if/when needed if not retreivable from said server vendor). Aruba provides no ECCN/HTS for the software itself (Clearpass, AirWave, etc)
Jerrod Howard
Hi Jerod,
Yes, could provide the ECCN and HTS for the DELL servres that have the 25k license CPPM deployed on it?
Mark
That list is here - http://i.dell.com/sites/doccontent/shared-content/solutions/en/Documents/HTS-ECCN-CCATS-Reference-Table-ver15-02.pdf
We have had different server models go out over the years, so it's best to look it up on this table based on the hardware model you have. Depending on when you received your server, it could be an R610, R620, or R630 which should all share the same ECCN.
Jerrod Howard
