Network Management
Enable and configure AppRF on Instant+Airwave
Hi, I am trying to enable AppRF on a 225/205/103 cluster. They are currently running 6.4.3.1-4.2.0.2_52056
I am managing them with Airwave 8.0.9
I wanted to enable AppRF on this, the instructions I've found refer to the Virtual controller, but all of the management elements appear disabled once connected to Airwave. Is there a way to enable this from Airwave or am I missing something blindingly obvious?
Re: Enable and configure AppRF on Instant+Airwave
Tim Cappalli | Aruba Security
So, it was blindingly obvious. I had not enabled "manage instant" on that custom group...but I had somehow allowed it to block mgmt on the VC level. Which seems like a bad combination to be able to do. :)
Anyway, now it is obvious where to config. Thanks so much.
Frequent Contributor II
if you want to manage IAPs by airwave and you added the airwave server, the GUI on the IAP itself is by default read-only, so you didn't really made that mistake ;-)
Thomas
ACMX#370 ACCX#1000
