Network Management
Occasional Contributor I
Enet0 and Enet1 don´t bring up
Best regards
I need help with the AP-225,  the interfaces Enet0 or Enet1 never up.
I test the patch core, POE, Sw, and are okey.
Please see the atached file.
i think the possible cause is the firmware,whats is the form to upgrade via usb by CLI?
being attentive
Steven
Re: Enet0 and Enet1 don´t bring up
Is this a new access point?  Is it an AP-225 or an IAP-225?
If it is an IAP-225, it is an Instant AP and you will need to configure it by joining your computer to the SSID (named "instant" I think?) it creates when you plug it in. It will not show up in your controller like a campus AP (standard AP-225) would. You can then convert it to a standard campus AP and it will show up on your controller.
HI Cjoseph
Yes, it is new AP-225, only i up the backup of before AP.
Hi rsinclair
The AP don´t show the instant SSID.
I explain more, the AP 225 its new, the first time that i plug the AP all good, show SSID instant and get IP with the local interface.
the friday i upload the backup of previous AP-225, and the AP don´t up the interface again afther this upload.
I reset to factory default and don´t bringup the interfaces.
Hi
i found the solution:
1. update the version to most recent.
2. via CLI i stop the boot process and assign the ip address.
3. After this process the ssid will be visible.
The Enet 0 or Enet 1 is active after this process
