Network Management
Enterprise licenses for Controllers
Hi, If I have a solution of 50 access points with RF, PEF and AW. I will consider 50 Enterprise licenses for the controller that includes the Airwave monitoring & management for the 50 access points.
My question is if that Enterprise licenses also allowed the Airwave to monitor the controller. Or do I have to adquire more Airwave licenses to manage and monitor the solution controllers?
Thanks!
If it helps please add Kudos
-Pepe
Re: Enterprise licenses for Controllers
You would need 51 licenses.  50 for the access points and 1 for the controller.
Colin Joseph
Aruba Customer Engineering
