Network Management
Contributor I
Error fetching configuration with Airwave from Cisco switches when telnet is disabled
I just noticed that if you disable telnet access in Cisco switches Airwave can't fetch the running configuration. I've looked around but i can't find any setting to force ssh or disable telnet when doing the fetching. Is this a feature or a bug? Shouldn't the default way to communicate be ssh and telnet be just in case ssh fails?
Or is it some setting i'm missing?
/Tomas
Re: Error fetching configuration with Airwave from Cisco switches when telnet is disabled
It should be in the "Groups" setting.
Go to :  https://<ip address of airwave box>/static/UserGuide/UserGuide.htm#AWUserGuide/Chapter3_Groups/Configuring_Basic_Group_S.htm
Contributor I
Thanks, i was looking under Device setup.
