Network Management
Error in CAD Layers
I'm having a problem when addin new floorplan from .dwg file. When I come to the importing walls from CAD file no matter what layer i choose I always get the same result and it ia not the right one - some seemengly random walls are marked as concrete no matter that I choosen outer doors and wood (see "Outer doors.jpg") or inner doors (see "Inner doors.jpg").
And if I scale building before going to the CAD Layers nothing happens at all.
Does someone know what is wrong?
Evgeniia
Re: Error in CAD Layers
Hi Evgeniia,
When you choose the wall type from drop down list in CAD layer the color of the wall type shows as red (concreate) only. It prompt the correct color code only after provisioning.
Sample dwg file which I uploaded in visularf it imported drywall (yellow color) succesfully.
I am able to scale the floor in AMP 8.2.3.1.
Pavan
If my post addresses your query , give kudos:)
Pavan
If my post address your queries, give kudos and accept as solution!
And what with scaling, it is OK that nå walls get marked as any type wall after I scale the building?
And how long it takes in genereal before walls can be seen after I'm done?
I am able to scale the floorplan. When you use dwg file, visularf automatically read the floor dimensions, we dont need to enter the values manually. You can crop unused space on floor plan using scale option.
Walls will prompt immeditely once you done with provisioning, make sure wall option is checked in Floorplan Features section.
Pavan
Pavan
When I upload .dwg file scaling is wrong (see "Scale.jpg"), building is not nearly 1 km long, and it is not so long when I check it in AutoCAD.
And it's gone at least 10 -15 minutes after I pressed "Finish" button but no walls had come up.
Please follow bleow community link which I posted few weeks back, which explain floorplan calucalation
http://community.arubanetworks.com/t5/Network-Management/VisualRF-resize-problem/m-p/290410#M6371
Regarding walls not showing after provisioning done, make sure check the box while selecting the wall type from drop down list in CAD layer.
Currently we have only four Wall Attenuations in VisualRF, if you have any different wall type, try manuall create new wall attenuation from Visualrf> Setup page.
I see you have selected wood type, since it is not present in the VisualRF attenuation list, it is not displaying.
Pavan
If my post addresses your query, give kudos:)
Pavan
I have added "Wood " to wall attenuation type list, so I should be able to choose it and see it on the map (see "Wall Attenuation Settings.jpg"). And I do check the box while selecting the wall type from drop down list in CAD layer (see "CAD Layer.jpg") but despite it I do not see any walls displayed on the map after I'm done, wall option is checked in Floorplan Features section (see "Result.jpg").
Hi ,
I have attached sample dwg floor plan, try test it in your server. I have set cad layer walls as concrete and you could see its been updated.
May I know your Airwave version, if it is in lower version try upgrade to 8.2.3.1. If sample one working and your dwg file fail to fetch walls then something issue with your file.
Pavan
Pavan
I have AirWave 8.2.3.1
I don't see attached .dwg file
Download Title Block (ansi)  file from below link
https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autocad-sample-files.html
Pavan
Pavan
