Network Management
Ethernet speed for groups
Hello! Absolute noob posting here but I've done some gigabit upgrades to a site that previously was reported to have the majority of APs running at 100 Mb. Is there a way I can see the ethernet link status of an entire group of APs? I know I can do one but instead of typing away at each one I would like a full summary of link speeds.
Thanks in advance.
Re: Ethernet speed for groups
Hey, there is no command to my knowledge as such to show the interface speeds for a specific ap-group. You would need to need to run the command individually (or a bit of cut and paste!). Do you have access to the switch, I expect you can probably get this information from there.
Failing that the quickest command to view the speed of an individual AP is below.
(Lab620) #show ap port status ap-name AM-xx:xx:xx:xx:xx
AP "AM-d8:c7:c8:ce:c3:0c" Port Status (updated every 60 seconds)
Port  MAC                Type  Forward Mode  Admin    Oper  Speed   Duplex  802.3az  PoE  STP  TX-Packets  TX-Bytes  RX-Packets  RX-Bytes
0     xx:xx:xx:xx:xx
  GE    N/A           enabled  up    1 Gb/s  full    N/A      N/A  N/A  633         121930    1763        186373
ACMA, ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
