Network Management
Frequent Contributor II
Export Visual RF maps WITH APs displayed?
Browsing the forum... don't see a way to do this:
Can Airwave output PDF or even JPG/PNG of floorplans that include access points?
Like so:
Currently I'm using screenshots, but I'd like to get be able to get something with higher resolution/quality, if possible.
Re: Export Visual RF maps WITH APs displayed?
You can try the below,
  • Go to Visualrf
  • Click on the list view for the maps
  • You would see download map option towards right
Vishnu
Vishnu
If my post helped you, don't forget to give kudos ;)
Sorry Vishnu, I'm asking for a map WITH APs displayed. Almost as if one were to create a PDF/PNG/ some file type of what is seen in Visual RF (without having to log in, click to the campus, building, floor).
I have been doing screenshots, but I assumed there must be a better approach?
Moderator
Try this:
For an individual floor:
From the view that shows the building as a stack of floors (drill down into campus, then drill down into the building)
Right click on a floor -> bill of materials, uncheck all options -> ok
The output should be a word doc with the raw floor showing AP placement.
You can also do this from the campus view to get an entire building, or even from the network view to get the entire campus.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Works for me. Good info, Rob.
Rob,
Thanks for the suggestion... unfortunately, I don't get any graphic, just a table listing AP info.
Like so:
Moderator
The word doc export should have a floor plan prior to the AP inventory table.
Mine returns:
If you're still not seing the floor plan like so, then please open a support case and a support engineer can help debug.
Rob Gin
Thanks, will do
"Create case" option seems to be futzed:
Moderator
Thanks for the heads up.  We recently migrated into the HPE tracking system, so things may have broken during the move.  Will get the admins to take a look into it.
Rob Gin
