Network Management
Contributor II
Re: Export Visual RF maps WITH APs displayed?
OK, I just tried again (to create a case)... no go. Same bug, webform looks wacky.
Could I get someone to create a case for me, in the meantime?
I'd really like to print out my building maps (without doing screenshots)
Moderator
@the.sleeper: I've pinged support to open a support case for you.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Contributor II
Rob/everyone,
OK, I finally got my issue cleared up (needed to delete a VRF cache)
Here's a sample map of what I get when I do the BOM:
I didn't realize at first that the APs were included--that's how small they are.
But if you zoom in, they are there:
So, its close, but is there any way to increase the size of the AP icon?
(I tried tweaking the size in VisualRF, but that didn't seem to have an effect.)
Currently we do not have option in Airwave to increase the AP size in BOM report, I would recommand to file feature request.
Pavan
Pavan
If my post address your queries, give kudos and accept as solution!
Contributor II
Thanks Pavan, could you point me to where to do that?
(btw, I'm still not able to create cases from threads)
You could login to support.arubanetworks.com site and go to contact suupport section and click on Access Feature Requests via Idea Portal
Pavan
Contributor II
