I'd like to create a template that looks for a single AAA profile with static information. Something like:
----begin template
aaa profile "wifi-aaa_prof"
authentication-dot1x "dot1x_prof-bna32"
dot1x-default-role "authenticated"
dot1x-server-group "wifi_srvgrp-slc59"
----end template
All I want Airwave to audit against is the above section, and all other configuration line items can be ignored. After creating the template above and applying to a group, then auditing the current versus desired config, I get a mismatch which is shown as below:
Actual aaa authentication captive-portal "Blah-cp_prof"
Desired
Actual aaa authenticaiton captive-portal "Guest-cp_prof"
This is the only entry of "Desired" but there's nothing there. I then modified the template to ONLY have
----begin template
hostname %hostname%
----end template
Which seems like all I should be looking for is whether it has a hostname, right? Well, the same result occurs. Has anyone else tried to do something like this, where you prune out a majority of a config and only look for one specific section?
Am I doing this completely wrong, or is this some sort of bug?
