Network Management
Globa setting for telnet / ssh credentials
New to Airwave. I am currently using it to monitor my HP / Aruba switches. as I have started to bring in my locations switches into thier repective groups I am getting a lot of mismatch alerts. the majortiy of them complaining about this. "Error(Telnet/SSH Error: No username specified) " I would prefer to not enter this information in per error / switch. Where can I set this globally please? Thanks.
Re: Globa setting for telnet / ssh credentials
Device Setup> Communication> Aruba> Edit.
I'm sorry. I forgot to mention that I had already done that. It seems to be being ignored. So I thought there may be somewhere else to do it. I am on 8.2.6.1
Moderator
The Device Setup -> Communications page is used when you first add the device (either manually or through discovery).  If the devices are already added, then you need to bulk edit from the Devices list view.
go to Devices list
create a view that shows only the devices with Config = Error
click the pencil at the top right of the list table to get bulk edit options
check all the devices that need updating
from the Device actions drop down, select "Update the credentials used to communicate with these devices", click update
it should take you to a view that prompts for the creds, input creds and click update
it'll then take you to a confirmation page, apply changes now
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
I did this already to fix the ones that were already wrong. What I am looking for is to not to have to do this in the future as I add more switches to the system. Thanks.
Moderator
New switches should observe the Device Setup -> Communication settings - unless you type something else in the fields at time of adding.
Rob Gin
presuming that this is the correct one for HP Procurve / HP Aruba switches I have already set that. device setup/communication/Aruba I had also done the same for the HPE  just to cover my bases.
Moderator
It depends on which switch models, there's several categories under Device Setup -> Communication for various Aruba / HPE models:
Aruba (covers general Aruba branded)
Aruba MAS
ArubaOS Switch
ArubaOS-CX Switch
HPE (covers general HPE branded)
HPE OfficeConnect Switch
I've also filed a few defects to simplify this, and to address that there's not a 1-1 mapping between Device Setup -> Add selection vs Device Setup -> Communication options.
Rob Gin
So I shotgunned it and did all the ones you listed:) One of those fixed it. I just pulled in another school of 23 switches with no SSL credentials issue. Thanks!
