Yesterday I tried to backup my flash to tftp server its giving an error message that says timeout but now when I tried to backup my flash again its telling
What does the TFTP server say?
Thanks for the reply. Its working now.
I have the same problem as this and I am trying to go to the solution but when I click on it it just refreshes the screen. Can someone send me the link to this solution?
How do you save the flash? thru tftp?
@rayray495! wrote: I have the same problem as this and I am trying to go to the solution but when I click on it it just refreshes the screen. Can someone send me the link to this solution?
rayray495,
Are you using a TFTP server? Does it have any logging? Do you have a firewall enabled on the computer with the TFTP server?
I am having this same issue. It says there is a solution posted, but the link goes nowhere. Can somebody help with this?
