Network Management
Help for generating a custom report in AirWave.
Hi.
I have problems for generate a specific custom report in Airwave. I need get information of "Top 10 applications by folder "  but this option dont exist. I try diferents options but I dont get good results.
Somebody know how a I get this report?
Re: Help for generating a custom report in AirWave.
AMP version 8.0.8.1
Thx in advanced.
You can create a report for specific folder or group but I don't think the report breaks it down into folder if you do select all groups and folders.
You can limit the output to 10 if required.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
I just ran a report and selected all groups and folders and it broke down the top 10 applications per SSID.
ACDX #420 | ACCA
