Network Management
Help logging into Airwave GUI
New to AirWave and Linux, but I think I have Airwave installed correctly in VirtualBox. See image below.
Not sure what to do next because I can't log into https://172.16.0.99 which is the IP address I gave AMP during the setup.
I can ping the VirtualBox machine, but not this address. Am I supposed to be able to ping this address?
Any other ideas?  Thanks
Frequent Contributor I
Re: Help logging into Airwave GUI
hi,
have you configured ethernet bridging correctly on virtualbox?
ACCP ACMP CWDP CWSP
I understand you have intalled Airwave on virtual box, may i know the host resource details?
 Have you installed virtual box on any PC and installed airwave?
We need to allocated atleast 8GB RAM and 4 cores intel xenon processor for Airwave to up and running and also make sure you have configured correct interface.
Pavan
If my post address your queries, give kudos and accept as solution!
The 'Killed' messages in your screenshot do suggest that the system ran out of memory. Please check Pavan's suggestion and double-check your assigned resources (specific memory and disk).
