Network Management
Contributor I
How I clear all IDS events in Airwave
How I clear all IDS events in Airwave at once?
Re: How I clear all IDS events in Airwave
2 options:
1. In AMP Setup, look at the "Radius/ARM/IDS Events" and set that to 1.  Wait 1 day and you will have just a days worth of events.
2. In RAPIDS --> IDS Events, there is a small downward pointing arrow icon next to "1-20" at the top/bottom left of the table.  Click on it and choose another number or custom and enter in the total number of events.  Then, tick "select all" at the bottom and hit delete.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
dglav60,
If you have the root password in Airwave, SSH into it and execute:
dbc 'delete from ids_event'
