Network Management
[How-To] Getting Clarity Live up and running in 5 minutes!
Here's a quick How-To on setting up Clarity Live!
PREREQUISITES
  • AirWave 8.2.x
  • AOS 6.4.3+
CONTROLLER SETUP
Clarity may already be enabled on the controller side. Let's take a look.
First, let's verify that the controller is already sending AMON data to AirWave.
  • From the CLI, type:
    show mgmt-servers
    If you've set up AMON in the past, you should see your server listed as type "AirWave".
    (controller) #show mgmt-servers
    List of Management Servers
    Type     Primary Server  Profile
    AirWave  1.2.3.4    default-amp
    If your AirWave server is not listed, add it by running the command:
    mgmt-server type amp primary-server <airwave-ip> profile default-amp
Now that we know AMON is configured, let's take a look at the AirWave profile and ensure that we're sending Clarity data.
In the last step, you saw a Profile attached to the AirWave server. By default we have "default-amp", but you may have created your own.
  • At the CLI, run:
    show mgmt-server profile <profile-name>
    //example:
    show mgmt-server profile default-amp
    You should see something similar to this:
    Mgmt Config profile "default-amp" (Predefined (editable))
    Parameter          Value
    Stats              Enabled
    Tag                Enabled
    Sessions           Enabled
    Monitored Info     Disabled
    Misc               Enabled
    Location           Enabled
    UCC Monitoring     Disabled
    AirGroup Info      Disabled
    Inline DHCP stats  Enabled
    Inline AP stats    Enabled
    Inline Auth stats  Enabled
    Inline DNS stats   Enabled
    If the parameters beginning with "Inline" are not enabled, start by entering the mgmt-profile config mode:
    Next, enable the Inline stats options using the commands below:
    no inline-ap-stats-disable
    no inline-auth-disable
    no inline-dhcp-disable
    no inline-dns-disable
    That's it! Be sure to save your config.
AIRWAVE
Clarity Live is enabled by default, but we can verify by going to AMP Setup > General > Additional AMP Services > Enable Clarity Data Collection. This should be set to Yes.
After a few minutes, you should begin seeing Clarity Live data!
Tim Cappalli | Aruba Security
Re: [How-To] Getting Clarity Live up and running in 5 minutes!
Any suggestions on what to check when Clarity still isn't showing data when the settings are configured as above?
Carson Hulcher
@carson_hulcher | ACDX 512 | ACCX 583 | ACMP
Enable AMON Data Collection:
Frequent Contributor I
Any ideas on why I would see these results when enabling the DHCP & DNS monitoring?
(SEN-A650) (Mgmt Config profile "default-amp") #no inline-dhcp-disable
DHCP monitoring configuration not supported on this platform
(SEN-A650) (Mgmt Config profile "default-amp") #no inline-dns-disable
DNS monitoring configuration not supported on this platform
I am running 6.4.3.7 on a 650 controller.
Michael McNamee
Sr. Network Engineer - SecurEdge Networks
ACMP / ACDX / AWMP
http://www.securedgenetworks.com/secure-edge-networks-blog/
Spoke to engineering. The 6xx controllers unfortunately cannot support Clarity Live due to memory requirements.
Does the clarity collect and display live data OR it polls at certain intervals?
The controller "pushes" the clarity data to Airwave using Amon.
Colin Joseph
Aruba Customer Engineering
We have Clarity running, and it looks good with 1 exception:
It shows the resultes from various DNS servers, but not the 2 actually being used! Clients get DNS addresses through DHCP.
Any idea why this happens?
Clients can statically assign the DNS server even when they receive their address via DHCP.
Good day All,
Any information on how it works in Hyper-V?.. Just installed using .ISO image of CE, however, it doesn't appear to be functional. My AMP server just doesn't see it even if all the settings in CE are applied and it can ping AMP.
