Network Management
Re: [How-To] Getting Clarity Live up and running in 5 minutes!
Hi Egor,
Are you talking about AOS code 8.0.x, if YES then we have support for this code in our latest Airwave release but related to clairty support it says from 6.5.x and later.
Since AOS 8.0.x code is new and in supported device list it is not mentioned clearily whether this code supports clarity data in Airwave or not.
Enable clarity settings in AMP Setup > General>Additional AMP services page aswell.
If all the setting enabled on AOS server side but still we are not seeing clairty data in Airwave then to confirm above (clarity support is there or not) we have to enable AMON debug logs in Airwave to see whether clarity data been sent to Airwave server or not?
Please open TAC ticket.
Pavan
If my code address your query, give kudos:)
Pavan
If my post address your queries, give kudos and accept as solution!
Thank you.
Clarity is enabled in Additional AMP Services. I can see its CPU/Memory consumption under APs/Devices. Its status is IDLE.
Airwave is 8.2.3.1.
Instant is 6.5.0.0-4.3.0.0_56428 (IAP-205). The highest I can see on HPE My Networking portal.
According to this thread:
https://community.arubanetworks.com/t5/Network-Management/no-data-collected-by-clarity/td-p/266404
I need a higher version of Instant.
At this point I've got nothing in Clarity Dashboard:
Egor,
I thought you are talking about controller code. Yes, clarity supported in IAP from 6.5.1.0-4.3.1.2 and this code is supported in AMP 8.2.3.1 latest version.
I would recommend to upgrade the IAP code and also Airwave if it in older code and check the status.
Pavan
Pavan
Updated to 6.5.1:
However, everything is pretty the same:
Also AppRF stopped working after the upgrade - no data there as well...
We have support for clarity in mentioned code, have you upgraded the Airwave code to latest aswell?
Pavan
Please create a new thread. This thread is about Clarity Live.
Tim Cappalli | Aruba Security
Super Contributor I
Hey!
I´m running Airwave 8.2.3.1 and ArubaOS 6.5.1.4 at a customer and I have enabled Clarity data collection on Airwave side and AMON + all the inline stats on the controller side. I can see all the stats showing up in Airwave except DNS, anything specific that needs to be done for the DNS stats to work?
Cheers,
Christoffer Jacobsson | Aranya AB
Aruba: ACMX #537 ACCP | CWNP: CWNA CWDP CWSP CWAP
Hi christoffer,
Make sure DNS stats also enabled, have you configured APs in split tunnel mode?
When RAP configured in split tunnel mode, Any DNS query performed by client will not hit controller. Hence, the information will not be passed to Airwave server.
I would recommand to open new TAC ticket to debug this issue, to see whether DNS data been sent from contorller to Airwave or not?
Pavan
Pavan
Super Contributor I
Hi!
The DNS stats are definately enabled to be sent from the controller. We have almost all VAPs in tunnel mode but no DNS stats are showing.
I will consider opening a TAC case at a later time.
Cheers,
Hi guys,
Finally, it works:
Had a chance to play with a newer IAP set up from scratch running the latest code - it appears something had been misconfigured in the original setup. Added back my original IAP-205 with wiped config - no problems so far.
IAP firmware:
Let's see how it goes. Thanks for your help. Cheers.
