Network Management
Contributor I
How to Configure SMTP settings on Airwave?
How to configure SMTP on airwave so I can recive emails on erros and so on,
I have read alot but didn't get where I add the email and password of email?
Re: How to Configure SMTP settings on Airwave?
on the AMP Setup page, you can configure the Email server there.
You can also configure a relay server.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
hi
to configure Airwave as a an SNMP Client  you go to
AMP Setup > NMS  then you add a new SNMP server.
Regards
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Not SNMP, SMTP... :)
ACDX #420 | ACCA
ok ,  i haven't   seen it  :)
Raouf CHAHBOUNE
Contributor I
Dears I have Tried to add the line but gives this
[root@localhost postfix]# main.cf: relayhost = [mail.airwave.com]
-bash: main.cf:: command not found
You can configure the relay host via the webUI.
In order to do it via the CLI, you need to edit main.cf with an editor like 'vi'
ACDX #420 | ACCA
Contributor I
Thanks but how to do it with VI as it is my first time with Airwave and I need to know more about it
Airwave uses postfix
For general basic configuration go here
http://www.postfix.org/BASIC_CONFIGURATION_README.html
As for Airwave, goto AMP setup -> General
You will see the following, choose yes to enable the mail server, then go create triggers
If you want to use a relay, you can set an IP address and test as well.
If you need to use something like a Gmail smtp server which requires authentication, then refer to the postfix help forums on how to configure that.
ACDX #420 | ACCA
Contributor I
have done this but it didn't work : for example :
My configs: Use embaded system :yes
to 123@gmail.com
from 123@gmail.com
send
it said msg sent successfully
but now msg apears at all
