Network Management
How to Delete a folder in AirWave
  • 1.  How to Delete a folder in AirWave
    Posted Dec 17, 2013 02:28 PM
    Thought this might be helpful to some.
    Note: The folder you wish to delete MUST NOT have any devices or subfolders.
  • 2.  RE: How to Delete a folder in AirWave
    Posted Dec 17, 2013 04:04 PM
    It's also worth noting that an ignored device counts as being something in the folder, so you can always check that by doing:
    # dbc 'select * from ap where ap_folder_id=(id that appears in folder view URL)
    Example:
    URL=demo.airwave.com/ap_list?ap_folder_id=1
    # dbc 'select * from ap where ap_folder_id=1'
    Can further be simplified to:
    # dbc 'select id, name, state from ap where ap_folder_id=1'
    This filters out the extra rows that don't matter if you're planning to delete the folder
    Database AP States:
    0 = pending
    1 = approved
    3 = ignored
  • 3.  RE: How to Delete a folder in AirWave
    Posted Mar 02, 2015 12:09 PM
    I can't delete a subfolder, even if it is empty (also check with dbc command):
    [root@airwave mercury]# dbc 'select id, name, state from ap where ap_folder_id=17'
    id | name | state
    (0 rows)
    The GUI seems to accept the command "Delete this folder" but then the folder is still there.
    Is there a way to force the deletion?
  • 4.  RE: How to Delete a folder in AirWave
    Posted Mar 02, 2015 12:56 PM
    it may be a database issue. please check /var/log/httpd/error.log and /var/log/pgsql at the time of an attempted delete. if theres no errors, then the delete should work, but usually a non delete means something else is crashing in the background. may be grounds to open a quick support case with TAC.
  • 5.  RE: How to Delete a folder in AirWave
    Posted Mar 03, 2015 04:18 AM
    You're right...
    Here what the error log says:
    delete_objects() - DBD::Pg::st execute failed: ERROR: update or delete on table "ap_folder" violates foreign key constraint "vpn_user_a"
    DETAIL: Key (id)=(17) is still referenced from table "vpn_user". [for Statement "DELETE FROM ap_folder WHERE
    id = ?" with ParamValues: 1='17'] at /usr/local/airwave/lib/perl/Mercury/DB/Q/st.pm line 20.
    Mercury::DB::Q::st::execute('Mercury::DB::Q::st=HASH(0x7f2f29689148)', 17) [...]
    Do I have to proceed with a support case?
