Network Management
How to Upgrade AirWave aka How to upgrade AMP?
Maybe you've wondered how to upgrade to the latest version of AirWave (aka AMP)?
It's not too hard, you just need access to the shell of the server with root access and internet access from the server. (this can be done from a local file too, but I won't get into that now)
SSH into the AirWave server using root and type: start_amp_upgrade
The entire upgrade should look like this:
root@localhost mercury]# start_amp_upgrade
Enter desired AMP version: 8.0.6.3
Directory not specified; using /root.
Upgrade script AMP-8.0.6.3-amp_upgrade was not found in local cache.
Upgrade package AMP-8.0.6.3-x86_64-cvs.tar.gz was not found in local cache.
Preparing to connect to Aruba Support Center...
Enter your Aruba Support Center username: emailaddress@arubanetworks.com
######################################################################## 100.0%
Checking for any patches or modifications to the code
This process may take a few minutes...
No outstanding changes were found. Continuing with the upgrade.
Validating the upgrade package...
Upgrade package is OK.
Upgrading AMP to version 8.0.6.3 from version 7.7.10...
Detailed log will be written to /var/log/upgrade/AMP-8.0.6.3-upgrade.log
STEP 1: Moving old version aside.
STEP 2: Unpacking upgrade package.
STEP 3: Checking for compatibility.
STEP 4: Stopping AMP services.
STEP 5: Installing upgrade.
Updated kernel packages that fix various security issues are now
available for your OS. To upgrade, run the command below and
reboot your system.
  cd /root/svn/mercury/src/x86_64/rpms/CentOS-6; rpm -Uvh kernel-2.6.32-504.1.3.el6.x86_64.rpm kernel-headers-2.6.32-504.1.3.el6.x86_64.rpm kernel-firmware-2.6.32-504.1.3.el6.noarch.rpm
For more information refer to the security advisory:
  https://rhn.redhat.com/errata/RHSA-2014-1843.html
STEP 6: Restarting AMP services.
[root@localhost mercury]#
There!! All done.
Re: How to Upgrade AirWave aka How to upgrade AMP?
Great guide,This part is very importent: (It's not done via the automatic upgrade process - booting without this step will cause your amp not to start as need)
reboot your system.
**Here is another (a bit old) guide**
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Tutorial-How-to-Upgrade-your-Airwave-Offline-Upgrade/td-p/85634
Contributor II
Worked perfect for me, thanks.  One thing you may want to add, step 5 takes a lonnnnnng time
