Network Management
How to add Ruckus AP's to Airwave
Could someone please give me a step-by-step list on how to add Ruckus AP's to Airwave.
Thanks in advance.
Kind Reagrds,
Rieyaad
Re: How to add Ruckus AP's to Airwave
Attached is the latest supported infrastructure devices in Airwave.
Ruckus is not in the list, so at most you would just get up/down and maybe interface info if you add it...
Hi Colin,
Yes that would be fine. Thanks for the list as well.
Do you have a step-by-step to add the AP's to Airwave?
Kind Regards,
Rieyaad
Device Setup> Add> Universal Network Device
