Network Management
How to create an Airwave report for all not in visualRF placed APs?
Dear all,
To verify our documentation I am looking for a report for all not in visualRF placed APs.
We are running Airwave version 8.0.11.1.
Many thanks for your support
Markus
Moderator
Re: How to create an Airwave report for all not in visualRF placed APs?
There's no such report, but what you can do is go to APs/Devices, create custom view that includes 'Floor'.  Then go to Top Folder, expand to show all devices, and you can sort by floor to see any APs that aren't placed (probably easier to export table to CSV at that point).
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Hi Rob,
was looking for something which can run autmatically every month but this will help me to create and export the required information manually.
Many thanks for this workaround
Markus
Moderator
The workaround is just temporary until a feature can be implemented.  But the next step would be to submit an RFE to be reviewed by the Product Management team.  To do this, you can submit through the ideas portal on the support site (so that other customers can upvote it), and also let your local sales rep know so that they can provide feedback.
Rob Gin
