Network Management
How to display historical client data per AP
We use a load of RAP boxes for off-site connectivity. Due to various staff changes there is no longer a proper record of whom has which.
I need to list the client devices that have connected to each RAP box so I can track down regular users & find out where the RAP box is located. How do I do this?
Re: How to display historical client data per AP
Airwave would do this for you. Or AN Other SNMP monitoring tool.
And you would only get data accumilating from when it was installed.
Controllers don't keep this type of historical data.
Cheers
James
-------------------@whereisjrw-------------------
------------------------blog-------------------------
