Network Management
Contributor I
How to locate rogue AP via virtualRF(Airwave 8.0.4)?
Hi all,
I'm trying to use virtualRF to locate rogue AP.
But I can't see any rogue APs on the floor plan.
And I found "last seen" colon on the rogue AP list was about 2 hours late.
(Top on the list, sorting with "last seen")
Does anybody have any idea about this issue?
Valued Contributor I
Re: How to locate rogue AP via virtualRF(Airwave 8.0.4)?
Do you have Rogue AP selected?
Contributor I
Yes, I do have Rogue AP selected.
Is there any document or tutorial about how to locate rogue AP via virtualRF?
