Network Management
Occasional Contributor I
How to monitor other vendor device in Airwave?
How to config the Airwave to monitor the other vendor device ?
Is there any best practices to do that?
Valued Contributor II
Re: How to monitor other vendor device in Airwave?
HI,
Similar way that you will add and monitor Aruba devices.just you need to add the device in monitoring mode.
Please please free for any further help on this.
Cheers,
Venu Puduchery,
Thanks your reply, where can I add the devices?
Trusted Contributor I
