Network Management
I have an existing controller with firmware version 6.4.2.3 and we are going to migrate to a new co
I have an existing controller with firmware version 6.4.2.3 and we are going to migrate to a new controller with firmware version 6.4.4.10. will there be any problems when migrating to the new controllers? Will my existing access points connect to the new controller?
Re: I have an existing controller with firmware version 6.4.2.3 and we are going to migrate to a new
What controller and APs do you currently have in production?
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect @WEI
We have AP 215 and aruba 7030 controller
1- I suggest you upgrade your current environment 6.4.4.10 this will make transition a bit smoother to the new controller running the same code version
2- from the HPE support portal transfer the licenses to the new controller and then apply the licenses keys to the new controller
3- if you have any certs installed you will need to transfer those manually since those are not included in the backup
4- perform a backup and restore to the new controller
5- if you keep the same ip for management then all you have to do is unplug the existing controller from the network and plug the new one
Get Outlook for iOS
Thank you
Victor Fabian
Get Outlook for iOS
Thank you
Victor Fabian
what if we downgrade the new controller  because the client doesn't want us to change the existing controller? will it work?
Yes
Get Outlook for iOS
Thank you
Victor Fabian
