Network Management
I want to generate reports using Airwave containing clients top 10 visited sites and activities etc
I am trying to generate an Airwave custom report but  I don't seem to find a report for client visited sites.
Is there a way to generate a report for this?
Thank you.
Re: I want to generate reports using Airwave containing clients top 10 visited sites and activities
You should be able to do AppRF reports in version 8.0 which is our next release.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Thank you for the quick reply.
I am looking forward on that release. :manhappy:
Will that also work for IAPs?
ACCP, ACMP, ACMX #294
mclarke@arubanetworks.com
