Network Management
Regular Contributor I
In Airwave how can I trigger or report on AP uplink Speed/Duplex
Looking for a way to report on or send email alrets for APs that have mismatched speed and duplex settings in Airwave.  Specifically we have 3000 APs globally and I want to help find Aps with bad cabling or mismatched settings (yellow/amber lights on ent port of AP).
I see in AirWave if I drill down on a specific AP it shows me what speed and duplex the AP is but I am looking for a way to see all 3000 at once or get alerts via email the ones discovered with issues.  I assume there is a database somewhere with all this info in it even if in CLI.
Frequent Contributor I
Re: In Airwave how can I trigger or report on AP uplink Speed/Duplex
I don't know about seting a trigger in Airwave. I run a script manually to email me the info on speed issues. One could put this in a cron job. Check out http://community.arubanetworks.com/t5/Wireless-Water-Cooler/Report-of-all-WAPs-connected-at-100-Mbp/m-p/206093#M517
thank you so much I will give it a shot.
