Network Management
In Airwave how do I move a deployed AP from one floor plan to another?
Re: In Airwave how do I move a deployed AP from one floor plan to another?
If you delete it from the current floor, then you will have the option to added in the other floor
Thank you
Victor Fabian
Lead Mobility Architect
Contributor II
Can't move any other way? Like cut/paste to the new floor?
Moderator
Deleting the AP from the floor plan and then re-provisioning onto a new floor plan is the only current method.  Though it's a good argument to file in a feature request.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
