Network Management
Trusted Contributor I
Inactive SSIDs
I have several old SSIDs that are still showing up in graphs.  Under AMP Setup, there's a retention period for 'inactive SSIDs', which I would say these are.  The retention period is set to 90 days, and the SSIDs have been inactive for at least a year.  Is there a place to manually purge old SSIDs?
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
Moderator
Re: Inactive SSIDs
I haven't tried in a while, but there's a 'cleanup_expired_ssids.pl' script in /root/svn/mercury/scripts.  If that doesn't do the trick, then please open a TAC case.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Re: Inactive SSIDs
Thanks for the suggestion. Unfortunately that didn't work. I'll check with
TAC.
