Network Management
Re: Installation and Config of SNMP Client for External Monitoring of Airwave Server
This is what is need the SNMPd for polling not just for Traps.
When you say feature request would this be achargeable as I would of thought monitoring a system is standard these day's?
Kind Regards,
James Clayton
wrote:
Sorry, you might have missed my edit.  So the code in-place generates SNMP traps based on events/triggers.  It doesn't setup SNMPD for polling.  It's a feature request to add into the ideas portal.
That's disappointing. Thank you.
Moderator
When the AMPCLI menu was introduced, there were a lot of things that users had control of that were missing.  8.2.5.1's introduction of the 'enter commands' option began to handle some things like date, top, daemons, while 8.2.6 will add ping, traceroute, snmpwalk, and some other cmds.
This thread is the 1st feedback about needing SNMPD poll-able, which means it wasn't on the radar from development/QA - that's where it'd be a feature request so that it reaches the product team.  Filing it just lets the product team know that it's something you'd like to see, and other customers can help upvote the idea since usually the requests with the most votes get implemented.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Surely there would be a roadmap to reintroduce those features?
Moderator
There is a roadmap that is being worked off of, but it's didn't have the above usage case.  This probably means the sample of customers who provided feedback didn't utilized external monitoring of AMP.
Rob Gin
